Ana içeriğe geç
Turtle Beach Ear Force X12 Slide Adjustment Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: adım 1, 1 resimden 1.
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: adım 2, 3 resimden 1. Turtle Beach Ear Force X12 Slide Adjustment Replacement: adım 2, 3 resimden 2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
Sonuç
Katha Patel
218 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Thompson Fall 2017 USF Tampa, Team S1-G3, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 538
