Ana içeriğe geç
Turtle Beach Ear Force XO One Adapter Buttons Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: adım 1, 1 resimden 1.
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: adım 2, 1 resimden 1.
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: adım 3, 3 resimden 1. Turtle Beach Ear Force XO One Adapter Buttons Replacement: adım 3, 3 resimden 2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: adım 3, 3 resimden 3.
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: adım 4, 1 resimden 1.
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joseph Lane
128 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Shastany Fall 2015 UMass Dartmouth, Team 3-1, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S3G1
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,638
