Ana içeriğe geç
Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: adım 1, 2 resimden 1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: adım 1, 2 resimden 2.
    • The microphone is a separate piece. So, unplug it from the headset.
  2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: adım 2, 2 resimden 1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: adım 2, 2 resimden 2.
    • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  3. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: adım 3, 3 resimden 1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: adım 3, 3 resimden 2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: adım 3, 3 resimden 3.
    • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
    • Then slide the windscreen off of the microphone.
Sonuç
Andrew Rudnick
281 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G36
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 2,789
