Ana içeriğe geç
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: adım 1, 2 resimden 1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: adım 1, 2 resimden 2.
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: adım 2, 2 resimden 1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: adım 2, 2 resimden 2.
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nancy Truong
375 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G36
4 Üyeler
12 adet Kılavuz yazıldı
7 Yorum
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - Yanıt
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Commandcorps - Yanıt
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 4,397
