Ana içeriğe geç
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: adım 1, 2 resimden 1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: adım 1, 2 resimden 2.
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: adım 2, 2 resimden 1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: adım 2, 2 resimden 2.
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nancy Truong
375 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G36
4 Üyeler
12 adet Kılavuz yazıldı
7 Yorum
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - Yanıt
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Commandcorps - Yanıt
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - Yanıt
Same here the slider broke on me and I really like my tb 500p i have had them for a couple years can't find replacement parts my fix was to take a 2mm thick piece of metal adjust the headphones where I wanted them and cut the metal piece to fit against the slider going the complete distance from the main part to the part that sticks out on the ear piece and then used black duck tape to hold it in place
max headstrong - Yanıt
I should also note that if done correctly it should be almost like putting the metal piece in a slot. Also I messed around seeing what worked best and it's best to put the metal piece on the outside of the headset so it pushes inward. Doesn't work so good if you put it on the inside let's see oh yea just in case it wasn't implied you also need to bend the metal to either match the curvature of the slider or curve it a little more for a tighter fit. Let me know if this.has helped any of you out I'd love to hear back on this subject
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 4,274
