Ana içeriğe geç
Turtle Beach Ear Force XO Seven Speaker Cone Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: adım 1, 2 resimden 1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: adım 1, 2 resimden 2.
    • Begin by placing your thumb on the plastic edge around the ear pad.
    • Get a good grip around the ear pad and gently separate it from the headset.
    • Apply the same instructions to remove the other foam pad off of the headset.
    • Make sure you continue to gently peel the ear pad from the headset until completely removed.
  2. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: adım 3, 2 resimden 1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: adım 3, 2 resimden 2.
    • A new speaker cone for these headphones will cost about $8 to $10 from amazon.com.
    • After removing the ear pads, unscrew the four Phillips head screws that hold the front plate on.
    • To avoid losing small screws, place them in a container.
  3. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: adım 4, 2 resimden 1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: adım 4, 2 resimden 2.
    • When removing the speaker cone plate, be careful not to drop it or put stress on the wires as they are very delicate.
    • Remove the speaker cone plate on a flat surface to prevent unnecessary stress on the wires.
    • The speaker cone is attached to the front plate. To replace, unsolder the wires from the two connection points.
  4. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: adım 5, 1 resimden 1.
    • Replace the speaker cone carefully in place of the old one.
    • Consider tinning the wires before soldering them on to the new speaker cone.
    • Solder the wires back on to the new speaker cone.
    • Reassemble the front plate.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jacob
166 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G36
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
I couldn't find the speaker cone at amazon. Does anyone have a link?
victorlborges - Yanıt
You need to buy a Broken Headset the use that to replace the speaker.
Andy Millett - Yanıt
Is there anywhere that i can buy replacement swivel part that hold the speaker
Robert bee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 5,586
