Ana içeriğe geç
Turtle Beach Elite Pro Left Speaker Replacement
Neye ihtiyacın var
  1. Turtle Beach Elite Pro Left Speaker  Replacement, Ear Cushion: adım 1, 1 resimden 1.
    • Firmly pinch ear cushion between thumb and forefinger.
    • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
    • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
    FixBot'a Sor
    Yorum Ekle
  2. Turtle Beach Elite Pro Left Speaker  Replacement: adım 2, 2 resimden 1. Turtle Beach Elite Pro Left Speaker  Replacement: adım 2, 2 resimden 2.
    • Rotate ear cushion counter-clockwise about half an inch.
    • The ear cushion should audibly snap out of place.
    • After it has audibly snapped out of place, lift the ear cushion off of the device.
    • During reassembly, rotate the ear cushion clockwise.
    FixBot'a Sor
    Yorum Ekle
  3. Turtle Beach Elite Pro Left Speaker  Replacement: adım 3, 2 resimden 1. Turtle Beach Elite Pro Left Speaker  Replacement: adım 3, 2 resimden 2.
    • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
    • Make sure that both the ear cushion and the orange plate have the same designation.
    • Once the pegs are aligned, push the new ear cushion in place.
    FixBot'a Sor
    Yorum Ekle
  4. Turtle Beach Elite Pro Left Speaker  Replacement, Left Speaker: adım 4, 1 resimden 1.
    • Remove the left ear cushion completely from the headset.
    • The left ear cushion will be on the side of the headset where the microphone and audio control is attached.
    FixBot'a Sor
    Yorum Ekle
  5. Turtle Beach Elite Pro Left Speaker  Replacement: adım 5, 2 resimden 1. Turtle Beach Elite Pro Left Speaker  Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
    FixBot'a Sor
    Yorum Ekle
  6. Turtle Beach Elite Pro Left Speaker  Replacement: adım 6, 2 resimden 1. Turtle Beach Elite Pro Left Speaker  Replacement: adım 6, 2 resimden 2.
    • Use the opening tool to separate the orange plate from the black base plate.
    • Focus on the wires that are connected to the speaker.
    FixBot'a Sor
    Yorum Ekle
  7. Turtle Beach Elite Pro Left Speaker  Replacement: adım 7, 1 resimden 1.
    • Using wire cutters, cut the two wires that are attached to the speaker.
    • Make sure to cut the wires as close to the speaker as possible, because these wires will be used in the next step.
    FixBot'a Sor
    Yorum Ekle
  8. Turtle Beach Elite Pro Left Speaker  Replacement: adım 8, 2 resimden 1. Turtle Beach Elite Pro Left Speaker  Replacement: adım 8, 2 resimden 2.
    • Replace the old speaker with the new speaker.
    • Using the soldering iron, solder the wires to the new speaker.
    • Make sure to solder the wires to their original locations on the speaker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexis Uribe
510 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 3,658
