Ana içeriğe geç
Turtle Beach REACT-R Joystick Covers Replacement
Neye ihtiyacın var
  1. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: adım 1, 3 resimden 1. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: adım 1, 3 resimden 2. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: adım 1, 3 resimden 3.
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
  2. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: adım 2, 3 resimden 1. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: adım 2, 3 resimden 2. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: adım 2, 3 resimden 3.
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
  3. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: adım 3, 3 resimden 1. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: adım 3, 3 resimden 2. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: adım 3, 3 resimden 3.
    • Gently twist off each thumb stick, using one hand to secure the base, and the other to twist off the thumb stick.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dodi Imam
613 İtibar
6 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 12
Son 30 gün: 46
Her zaman: 470
