Ana içeriğe geç
Turtle Beach REACT-R Joystick Covers Replacement
Neye ihtiyacın var
    1. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: adım 1, 3 resimden 1. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: adım 1, 3 resimden 2. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: adım 1, 3 resimden 3.
      • Place the controller face down.
      • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
      • Use both hands to lift the backplate away from the controller.
      FixBot'a Sor
      Yorum Ekle
    1. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: adım 2, 3 resimden 1. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: adım 2, 3 resimden 2. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: adım 2, 3 resimden 3.
      • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
      • Two of the screws are hidden under the red and black vibration motor wires.
      • Gently lift the motherboard up and out of the chassis.
      • Be careful not to strain the vibration motor wires.
      FixBot'a Sor
      Yorum Ekle
    1. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: adım 3, 3 resimden 1. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: adım 3, 3 resimden 2. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: adım 3, 3 resimden 3.
      • Gently twist off each thumb stick, using one hand to secure the base, and the other to twist off the thumb stick.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Dodi Imam
697 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 81
Her zaman: 1,445
