Ana içeriğe geç
Turtle Beach REACT-R Vibration Motors Replacement
Neye ihtiyacın var
    1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: adım 1, 3 resimden 1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: adım 1, 3 resimden 2. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: adım 1, 3 resimden 3.
      • Place the controller face down.
      • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
      • Use both hands to lift the backplate away from the controller.
      FixBot'a Sor
      Yorum Ekle
    1. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: adım 2, 3 resimden 1. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: adım 2, 3 resimden 2. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: adım 2, 3 resimden 3.
      • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
      • Two of the screws are hidden under the red and black vibration motor wires.
      • Gently lift the motherboard up and out of the chassis.
      • Be careful not to strain the vibration motor wires.
      FixBot'a Sor
      Yorum Ekle
    1. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: adım 3, 3 resimden 1. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: adım 3, 3 resimden 2. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: adım 3, 3 resimden 3.
      • Be careful not to damage the vibration motors by dangling the wires.
      • Place the motherboard down on its back.
      • Grip white rumble motor connector and pull it directly out of its socket to disconnect it from the motherboard. Repeat for the other motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Dodi Imam
697 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 48
Her zaman: 509
