Ana içeriğe geç
Turtle Beach REACT-R Vibration Motors Replacement
Neye ihtiyacın var
  1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: adım 1, 3 resimden 1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: adım 1, 3 resimden 2. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: adım 1, 3 resimden 3.
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
  2. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: adım 2, 3 resimden 1. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: adım 2, 3 resimden 2. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: adım 2, 3 resimden 3.
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
  3. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: adım 3, 3 resimden 1. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: adım 3, 3 resimden 2. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: adım 3, 3 resimden 3.
    • Be careful not to damage the vibration motors by dangling the wires.
    • Place the motherboard down on its back.
    • Grip white rumble motor connector and pull it directly out of its socket to disconnect it from the motherboard. Repeat for the other motor.
Sonuç
Dodi Imam
613 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 106
