Ana içeriğe geç
Turtle Beach Recon Controller Front Buttons Replacement
Neye ihtiyacın var
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: adım 1, 3 resimden 1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: adım 1, 3 resimden 2. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: adım 1, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
    FixBot'a Sor
    Yorum Ekle
  2. Turtle Beach Recon Controller Front Buttons Replacement: adım 2, 3 resimden 1. Turtle Beach Recon Controller Front Buttons Replacement: adım 2, 3 resimden 2. Turtle Beach Recon Controller Front Buttons Replacement: adım 2, 3 resimden 3.
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
    FixBot'a Sor
    Yorum Ekle
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: adım 3, 2 resimden 1. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: adım 3, 2 resimden 2.
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Turtle Beach Recon Controller Front Buttons Replacement: adım 4, 2 resimden 1. Turtle Beach Recon Controller Front Buttons Replacement: adım 4, 2 resimden 2.
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
    FixBot'a Sor
    Yorum Ekle
  5. Turtle Beach Recon Controller Front Buttons Replacement: adım 5, 3 resimden 1. Turtle Beach Recon Controller Front Buttons Replacement: adım 5, 3 resimden 2. Turtle Beach Recon Controller Front Buttons Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: adım 6, 3 resimden 1. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: adım 6, 3 resimden 2. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: adım 6, 3 resimden 3.
    • Gently remove front buttons from the face plate by hand.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mary Goodrow
716 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Botvin Spring 2024 UMass Dartmouth, Team 6-1, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 714
