Ana içeriğe geç
Turtle Beach Recon Controller Motherboard Replacement
Neye ihtiyacın var
  1. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: adım 1, 3 resimden 1. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: adım 1, 3 resimden 2. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: adım 1, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Motherboard Replacement: adım 2, 3 resimden 1. Turtle Beach Recon Controller Motherboard Replacement: adım 2, 3 resimden 2. Turtle Beach Recon Controller Motherboard Replacement: adım 2, 3 resimden 3.
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Motherboard Replacement, Face Plate: adım 3, 2 resimden 1. Turtle Beach Recon Controller Motherboard Replacement, Face Plate: adım 3, 2 resimden 2.
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Motherboard Replacement: adım 4, 2 resimden 1. Turtle Beach Recon Controller Motherboard Replacement: adım 4, 2 resimden 2.
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Motherboard Replacement: adım 5, 3 resimden 1. Turtle Beach Recon Controller Motherboard Replacement: adım 5, 3 resimden 2. Turtle Beach Recon Controller Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: adım 6, 2 resimden 1. Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: adım 6, 2 resimden 2.
    • Use your fingers to lift both of the joystick caps off of the motherboard.
    • Remove the joystick caps.
  7. Turtle Beach Recon Controller Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Nothing can be further removed from the motherboard. It can now be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mary Goodrow
671 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Botvin Spring 2024 UMass Dartmouth, Team 6-1, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G1
3 Üyeler
1Rehber Yorum
thanks for posting this!
Sean Malter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 51
Her zaman: 640
