Ana içeriğe geç
Turtle Beach Stealth Ultra Front Facing Buttons Replacement
Neye ihtiyacın var
  1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Back Plate: adım 1, 2 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Back Plate: adım 1, 2 resimden 2.
    • Use tweezers to pull out rubber pieces in front of the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 2, 2 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 2, 2 resimden 2.
    • Remove the 10 mm screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 3, 2 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 3, 2 resimden 2.
    • Remove the sticker on the back of the plate.
    • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 4, 3 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 4, 3 resimden 2. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 4, 3 resimden 3.
    • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
    • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
    • Be cautious not to break the LCD screen while you move the opening tool around.
    FixBot'a Sor
    Yorum Ekle
  5. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 5, 3 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 5, 3 resimden 2. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 5, 3 resimden 3.
    • Use an opening tool to detach the front plate from the back.
    • You may need to work the opening tool all the way around the seam between the two plates.
    FixBot'a Sor
    Yorum Ekle
  6. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Motherboard: adım 6, 2 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 10 mm screws connecting the handles to the controller frame.
    FixBot'a Sor
    Yorum Ekle
  7. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 7, 1 resimden 1.
    • Detach the cables from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 8, 1 resimden 1.
    • Remove the yellow ribbon cable from the handle.
    FixBot'a Sor
    Yorum Ekle
  9. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 9, 2 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 9, 2 resimden 2.
    • Remove the six 10 mm screws connected to the motherboard using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: adım 10, 1 resimden 1.
    • Gently pull the motherboard away from the frame.
    FixBot'a Sor
    Yorum Ekle
  11. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Front Facing Buttons: adım 11, 2 resimden 1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Front Facing Buttons: adım 11, 2 resimden 2.
    • Pull the buttons out from the front plate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic Dodge
814 İtibar
7 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-7, McMurrin Fall 2025 Utah Tech University, Team 1-7, McMurrin Fall 2025 üyesi
UTAHTECH-MCMURRIN-F25S1G7
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 111
Her zaman: 605
