Ana içeriğe geç
Two-Hole Button Replacement
Neye ihtiyacın var
  1. Two-Hole Button Replacement, Two-Hole Button: adım 1, 1 resimden 1.
    • Choose a thread that will match the rest of the buttons on the jacket/button.
  2. Two-Hole Button Replacement: adım 2, 1 resimden 1.
    • Thread the needle so that there is equal thread on both sides of the needle.
  3. Two-Hole Button Replacement: adım 3, 2 resimden 1. Two-Hole Button Replacement: adım 3, 2 resimden 2.
    • Tie a knot at the end of the thread so that it will not come back through the buttonhole.
  4. Two-Hole Button Replacement: adım 4, 1 resimden 1.
    • Place the button on the fabric that you are sewing it back on to.
  5. Two-Hole Button Replacement: adım 5, 2 resimden 1. Two-Hole Button Replacement: adım 5, 2 resimden 2.
    • Take the threaded needle and push it through the fabric and one of the buttonholes on the bottom side and pull it through.
  6. Two-Hole Button Replacement: adım 6, 2 resimden 1. Two-Hole Button Replacement: adım 6, 2 resimden 2.
    • Thread the needle down through the second hole of the button.
  7. Two-Hole Button Replacement: adım 7, 1 resimden 1.
    • Place a straight pin on the backside of the button to keep the button from being sewn on too tight.
  8. Two-Hole Button Replacement: adım 8, 2 resimden 1. Two-Hole Button Replacement: adım 8, 2 resimden 2.
    • Repeat steps 5-6 to continue sewing the button on until secure.
  9. Two-Hole Button Replacement: adım 9, 2 resimden 1. Two-Hole Button Replacement: adım 9, 2 resimden 2.
    • Once the button is secure, push the needle through the fabric but not the button and remove the pin.
  10. Two-Hole Button Replacement: adım 10, 2 resimden 1. Two-Hole Button Replacement: adım 10, 2 resimden 2.
    • Once the pin is removed, wrap the thread around the button 6-7 times and push the needle through the fabric on the underside of the button.
  11. Two-Hole Button Replacement: adım 11, 3 resimden 1. Two-Hole Button Replacement: adım 11, 3 resimden 2. Two-Hole Button Replacement: adım 11, 3 resimden 3.
    • To finish sewing, make 3-4 stitches to tie off.
  12. Two-Hole Button Replacement: adım 12, 3 resimden 1. Two-Hole Button Replacement: adım 12, 3 resimden 2. Two-Hole Button Replacement: adım 12, 3 resimden 3.
    • Cut the remaining thread off.
Sonuç
Test out your fix by closing the jacket/clothing item with your resewn button!
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 132
