Giriş
Removing the drone cover is the only way to access many of the inner components of the U818A.
Neye ihtiyacın var
Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
3 farklı kişi bu kılavuzu tamamladı.
