Giriş
The DC motors which power the propellers are relatively easy to break. Fortunately, they are also relatively easy to replace. By purchasing a cheap U842 motor (either U842-03 or -04 for counterclocwise and clockwise motors respectively) and following these simple instructions, your drone will be flying again in no time.
Neye ihtiyacın var
To open up the motor housing, first remove the bottom light by unscrewing,
One 6mm Phillips screw.
Unscrew the single propeller bumper screw on the outside of the of the motor housing.
Unscrew the three screws on the perimeter of the motor casing.
Three 6mm Phillips screws.
Remove the motor casing by pulling up on the edges of the prismatic housing.
Remove the three motor mounting screws.
Use a thin blade or an X-ACTO knife to slice along the bottom of the wax to free the plug.
Unscrew the two mounting bracket screws on the front of the motor.
To purchase replacement parts,
2 farklı kişi bu kılavuzu tamamladı.
