Ana içeriğe geç
UE BOOM 2 Micro-USB Port Replacement
Neye ihtiyacın var
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: adım 1, 2 resimden 1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: adım 1, 2 resimden 2.
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: adım 2, 2 resimden 1. UE BOOM 2 Micro-USB Port Replacement: adım 2, 2 resimden 2.
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: adım 3, 3 resimden 1. UE BOOM 2 Micro-USB Port Replacement: adım 3, 3 resimden 2. UE BOOM 2 Micro-USB Port Replacement: adım 3, 3 resimden 3.
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
    Jordan Baxter (jbax92) - Yanıt
  4. UE BOOM 2 Micro-USB Port Replacement: adım 4, 1 resimden 1.
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: adım 5, 3 resimden 1. UE BOOM 2 Micro-USB Port Replacement: adım 5, 3 resimden 2. UE BOOM 2 Micro-USB Port Replacement: adım 5, 3 resimden 3.
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Alex Bahm
2.226 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S12G5
2 Üyeler
15 adet Kılavuz yazıldı
6 Yorum
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Yanıt
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Yanıt
i too am looking to find the replacement part
Liam Nicholls - Yanıt
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Yanıt
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Yanıt
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
Shannon Leclair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 148
Her zaman: 8,302
