Ana içeriğe geç
UP! Plus 2 Spool Holder Replacement
Neye ihtiyacın var
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: adım 1, 1 resimden 1.
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: adım 2, 3 resimden 1. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: adım 2, 3 resimden 2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: adım 2, 3 resimden 3.
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: adım 3, 3 resimden 1. UP! Plus 2 Spool Holder Replacement, Remove spool holder: adım 3, 3 resimden 2. UP! Plus 2 Spool Holder Replacement, Remove spool holder: adım 3, 3 resimden 3.
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: adım 4, 3 resimden 1. UP! Plus 2 Spool Holder Replacement, Replace spool holder: adım 4, 3 resimden 2. UP! Plus 2 Spool Holder Replacement, Replace spool holder: adım 4, 3 resimden 3.
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
valerie boyer
508 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G31
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,270
