Ana içeriğe geç
UP! Plus 2 Nozzle Replacement
Neye ihtiyacın var
  1. UP! Plus 2 Nozzle Replacement, Turn on your printer: adım 1, 1 resimden 1.
    • Plug in the AC Power adapter and USB cable into the back of the printer.
    • Connect your printer to the computer via USB.
    • Turn on the printer and initialize it.
  2. UP! Plus 2 Nozzle Replacement, Verify the nozzle temperature: adım 2, 1 resimden 1.
    • Open the UP! software on your computer, and bring up the "maintenance window."
    • Under maintenance, click "extrude."
    • Then, verify if the nozzle temperature is rising by looking at the status box in the same maintenance window.
  3. UP! Plus 2 Nozzle Replacement, Remove nozzle: adım 3, 2 resimden 1. UP! Plus 2 Nozzle Replacement, Remove nozzle: adım 3, 2 resimden 2.
    • The nozzle needs to be greater than 200 degrees Celsius before removal.
    • Before handling the nozzle please put on heat resistant gloves in order to prevent burns.
    • Using the 6mm hex wrench, apply force by pushing up to lock the nozzle into the wrench and turn counterclockwise to loosen the nozzle.
  4. UP! Plus 2 Nozzle Replacement, Attach the new nozzle: adım 4, 1 resimden 1.
    • Before attaching the new nozzle, make sure the temperature is still greater than 200 degrees Celsius.
    • Attach the new nozzle with the hex wrench by screwing it on in a clockwise manner.
    • If there is any extra plastic coming out of the extruder, cut it off before attaching the new nozzle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
valerie boyer
508 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G31
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
I have a problem with my UP PLUS 3D printer and I really need your help. First printer started to stop in the middle of the printing, then got to the point where I wasn’t even able to connect it to my laptop (it didn’t recognize it) and now, when I press Print, before even slicing completes, the software crashes and I have to reopen (basically I can’t print anything as every time I try, same thing happens). The weird part is that sometimes I can adjust the bed, heat up extruder, extract or retract filament from software but the moment I press print, it dies. PLEASE HELP!!!
Nima - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 2,738
