Ana içeriğe geç
USB Installation Media Creation
Neye ihtiyacın var
  1. USB Installation Media Creation, Download Rufus: adım 1, 3 resimden 1. USB Installation Media Creation, Download Rufus: adım 1, 3 resimden 2. USB Installation Media Creation, Download Rufus: adım 1, 3 resimden 3.
    • THIS PROCEDURE WILL ERASE THE TARGET USB DRIVE! BACKUP THE DRIVE OR USE A NEW ONE IF YOU DO NOT HAVE A DRIVE THAT CAN BE ERASED.
    • If you are reusing an old drive, format it first!
    • To write the ISO, download Rufus. Place this somewhere it is easily found.
    FixBot'a Sor
    Yorum Ekle
  2. USB Installation Media Creation, Download your ISO: adım 2, 3 resimden 1. USB Installation Media Creation, Download your ISO: adım 2, 3 resimden 2. USB Installation Media Creation, Download your ISO: adım 2, 3 resimden 3.
    • Authors note: While this guide is being demoed with Linux, it can be used with any bootable ISO - Windows images*, Linux ISOs, utilities like Parted Magic and more.
    • *Windows 11, in it's stock form requires a Microsoft account unless you use the latest version. For writing Windows 11 images, I have made a guide to cover how to work around this. Windows 10 and older do not need this precaution, but versions prior to 3.x will not account for this change.
    • Torrent clients require additional configuration NOT COVERED in this guide. Some distros offer this option and you can use it but every torrent client is a little different.
    • After downloading Rufus, download the ISO you want to write to the USB drive.
    FixBot'a Sor
    Yorum Ekle
  3. USB Installation Media Creation, Locate the ISO: adım 3, 3 resimden 1. USB Installation Media Creation, Locate the ISO: adım 3, 3 resimden 2. USB Installation Media Creation, Locate the ISO: adım 3, 3 resimden 3.
    • Default download locations: Windows (Recent versions; 7 and newer): Downloads
    • Plug the USB drive in and select the ISO you want to use.
    FixBot'a Sor
    Yorum Ekle
  4. USB Installation Media Creation, Writing the ISO file: adım 4, 3 resimden 1. USB Installation Media Creation, Writing the ISO file: adım 4, 3 resimden 2. USB Installation Media Creation, Writing the ISO file: adım 4, 3 resimden 3.
    • If you are using a system with a buggy Legacy BIOS, consider adding "Add fixes for older BIOSes".
    • Open Rufus and click SELECT. Find the ISO and click Open.
    • Rufus will ask you to choose ISO or DD mode. If unsure, choose ISO mode.
    • After configuring the writing process, click start. Click OK on the formatting warning.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
15 farklı kişi bu kılavuzu tamamladı.
Nick
103.873 İtibar
69 adet Kılavuz yazıldı
2Kılavuz Yorumları
Unetbootin does not work anymore and is considered unstable to use when installing any Linux OS, also 4GB USB drives are more than big enough to get the job done
Will - Yanıt Paylaş
My reasoning for saying 8GB is because 4GB sticks are all but nonexistent (8GB is more popular now), but if you already own the 4GB stick then it'll work. I even use one from 2006 in the guide, to show that reuse is possible.
Oh really? I always thought it was still a usable option - thanks for letting me know that I was wrong.
Nick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 25
Son 30 gün: 132
Her zaman: 5,733
