Ana içeriğe geç
USB/Auxiliary Port
Neye ihtiyacın var
  1. USB/Auxiliary Port, Outer Case: adım 1, 2 resimden 1. USB/Auxiliary Port, Outer Case: adım 1, 2 resimden 2.
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
    FixBot'a Sor
    Yorum Ekle
  2. USB/Auxiliary Port: adım 2, 1 resimden 1.
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
    FixBot'a Sor
    Yorum Ekle
  3. USB/Auxiliary Port: adım 3, 1 resimden 1.
    • Slide out the rubber foot located on the bottom of the case.
    FixBot'a Sor
    Yorum Ekle
  4. USB/Auxiliary Port: adım 4, 1 resimden 1.
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
    FixBot'a Sor
    Yorum Ekle
  5. USB/Auxiliary Port: adım 5, 3 resimden 1. USB/Auxiliary Port: adım 5, 3 resimden 2. USB/Auxiliary Port: adım 5, 3 resimden 3.
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
    FixBot'a Sor
    Yorum Ekle
  6. USB/Auxiliary Port, USB/Auxiliary Port: adım 6, 2 resimden 1. USB/Auxiliary Port, USB/Auxiliary Port: adım 6, 2 resimden 2.
    • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
    FixBot'a Sor
    Yorum Ekle
  7. USB/Auxiliary Port: adım 7, 1 resimden 1.
    • Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
    • It should come off after prying up the first tab.
    FixBot'a Sor
    Yorum Ekle
  8. USB/Auxiliary Port: adım 8, 3 resimden 1. USB/Auxiliary Port: adım 8, 3 resimden 2. USB/Auxiliary Port: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Carefully lift out the end panel.
    • Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands.
    • There is a bit of glue to hold the connection ribbon down.
    FixBot'a Sor
    Yorum Ekle
  9. USB/Auxiliary Port: adım 9, 1 resimden 1.
    • Remove the 5mm T6 screw holding the port assembly onto the end cap.
    • Unlike the flat top screw holding the metal housing, these screws are roundtop.
    FixBot'a Sor
    Yorum Ekle
  10. USB/Auxiliary Port: adım 10, 1 resimden 1.
    • Remove the old port assembly from the end cap.
    • Alternate Reassembly required, read on.
    FixBot'a Sor
    Yorum Ekle
  11. USB/Auxiliary Port: adım 11, 1 resimden 1.
    • Disconnect the Motherboard connection ribbon from the motherboard.
    • The ribbon should no longer be connected at either end.
    FixBot'a Sor
    Yorum Ekle
  12. USB/Auxiliary Port: adım 12, 1 resimden 1.
    • Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  13. USB/Auxiliary Port: adım 13, 1 resimden 1.
    • Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
    • ZIF connectors are delicate and often give beginners trouble, search for ZIF connector tips on the web.
    FixBot'a Sor
    Yorum Ekle
  14. USB/Auxiliary Port: adım 14, 2 resimden 1. USB/Auxiliary Port: adım 14, 2 resimden 2.
    • Position the new port assembly on the end cap and reinsert the 5mm T6 screw.
    • The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
    FixBot'a Sor
    Yorum Ekle
  15. USB/Auxiliary Port: adım 15, 2 resimden 1. USB/Auxiliary Port: adım 15, 2 resimden 2.
    • Reconnect the button ribbon connector on the top of the port assembly.
    FixBot'a Sor
    Yorum Ekle
  16. USB/Auxiliary Port: adım 16, 2 resimden 1. USB/Auxiliary Port: adım 16, 2 resimden 2.
    • Reconnect the endcap to the plastic housing.
    • While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  17. USB/Auxiliary Port: adım 17, 1 resimden 1.
    • Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
    • Finish reassembling in descending order starting at step 5.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow steps 1 through 5 in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Noah Sadler
548 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G1
5 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
Can anyone at all tell us where we can definitely purchase the USB/Auxiliary Port and its Motherboard to Aux Port ZIF Ribbon?
Thanks in advance.
barrysum - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 67
Her zaman: 15,928
