Ana içeriğe geç
UTILITECH #HVT-8H Motor Replacement
Neye ihtiyacın var
  1. UTILITECH #HVT-8H Motor Replacement, Motor: adım 1, 1 resimden 1.
    • Use a spudger to remove the screw covers.
    • Pry gently to avoid breaking the clips.
  2. UTILITECH #HVT-8H Motor Replacement: adım 2, 3 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 2, 3 resimden 2. UTILITECH #HVT-8H Motor Replacement: adım 2, 3 resimden 3.
    • Use your Phillips #0 screwdriver to remove the 8 mm screw that attaches the fan to its stand.
    • Repeat step 1 and 2 on the other side of the fan.
  3. UTILITECH #HVT-8H Motor Replacement: adım 3, 2 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 3, 2 resimden 2.
    • Use a spudger to remove the silver screw cover from the front of the fan.
    • Do not try to force the piece off as it could break. Instead, gently pry around the entire fan until it pops loose.
  4. UTILITECH #HVT-8H Motor Replacement: adım 4, 2 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws that hold the fan cover in place.
  5. UTILITECH #HVT-8H Motor Replacement: adım 5, 3 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 5, 3 resimden 2. UTILITECH #HVT-8H Motor Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the two 8 mm screws that attach the motor assembly to the base of the fan.
  6. UTILITECH #HVT-8H Motor Replacement: adım 6, 3 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 6, 3 resimden 2. UTILITECH #HVT-8H Motor Replacement: adım 6, 3 resimden 3.
    • Remove the power control knob by pulling on the knob backward.
    • Use a 10 mm socket wrench to remove the 10 mm nut that holds the power control piece in place.
  7. UTILITECH #HVT-8H Motor Replacement: adım 7, 2 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 8 mm screws that fasten the power plug to the base.
  8. UTILITECH #HVT-8H Motor Replacement: adım 8, 3 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 8, 3 resimden 2. UTILITECH #HVT-8H Motor Replacement: adım 8, 3 resimden 3.
    • Cut the two black cables to release them from the motor assembly.
    • Be sure to cut as closely as you can to the base of the cables so you don't lose a lot of length.
  9. UTILITECH #HVT-8H Motor Replacement: adım 9, 2 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 9, 2 resimden 2.
    • Use a wire stripper on the black wires to expose the metal underneath the rubber.
    • Strip about 13 mm from the end of both wires.
  10. UTILITECH #HVT-8H Motor Replacement: adım 10, 2 resimden 1. UTILITECH #HVT-8H Motor Replacement: adım 10, 2 resimden 2.
    • Connect the exposed power plug wires to the new motor assembly by twisting the two exposed wires together.
    • Wrap electrical tape around the newly connected wires.
Sonuç
Joseph Pemberton
181 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 84
