Ana içeriğe geç
UTStarcom CDM8945vw Keyboard Replacement
Neye ihtiyacın var
  1. UTStarcom CDM8945vw Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
    FixBot'a Sor
    Yorum Ekle
  2. UTStarcom CDM8945vw Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. UTStarcom CDM8945vw Keyboard Replacement, Antenna: adım 3, 1 resimden 1.
    • Identify the antenna. It is the extendable plastic component pictured here.
    FixBot'a Sor
    Yorum Ekle
  4. UTStarcom CDM8945vw Keyboard Replacement: adım 4, 1 resimden 1.
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
    FixBot'a Sor
    Yorum Ekle
  5. UTStarcom CDM8945vw Keyboard Replacement: adım 5, 2 resimden 1. UTStarcom CDM8945vw Keyboard Replacement: adım 5, 2 resimden 2.
    • The antenna should slide right out of the phone when finished.
    FixBot'a Sor
    Yorum Ekle
  6. UTStarcom CDM8945vw Keyboard Replacement, Speaker: adım 6, 1 resimden 1.
    • Remove the small rubber grommet using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  7. UTStarcom CDM8945vw Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove five screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. UTStarcom CDM8945vw Keyboard Replacement: adım 8, 1 resimden 1.
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
    FixBot'a Sor
    Yorum Ekle
  9. UTStarcom CDM8945vw Keyboard Replacement: adım 9, 1 resimden 1.
    • Remove the back piece of the outer case.
    FixBot'a Sor
    Yorum Ekle
  10. UTStarcom CDM8945vw Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. UTStarcom CDM8945vw Keyboard Replacement: adım 11, 2 resimden 1. UTStarcom CDM8945vw Keyboard Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. UTStarcom CDM8945vw Keyboard Replacement, Logic Board: adım 12, 1 resimden 1.
    • Detach the highlighted piece from the logic board using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  13. UTStarcom CDM8945vw Keyboard Replacement: adım 13, 2 resimden 1. UTStarcom CDM8945vw Keyboard Replacement: adım 13, 2 resimden 2.
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  14. UTStarcom CDM8945vw Keyboard Replacement, Keyboard: adım 14, 1 resimden 1.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bryon Hazlewood
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-26, Regan Fall 2012 Cal Poly, Team 24-26, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G26
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 515
