Ana içeriğe geç
UTStarcom XV6700 Camera Replacement
Neye ihtiyacın var
    1. UTStarcom XV6700 Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Press the on/off button on the top to power the phone off.
      FixBot'a Sor
      Yorum Ekle
    2. UTStarcom XV6700 Camera Replacement: adım 2, 1 resimden 1.
      • Remove the battery cover by pressing and sliding the cover down and off of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. UTStarcom XV6700 Camera Replacement: adım 3, 3 resimden 1. UTStarcom XV6700 Camera Replacement: adım 3, 3 resimden 2. UTStarcom XV6700 Camera Replacement: adım 3, 3 resimden 3.
      • Pull the battery removal tab and lift the battery out of the phone.
      • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
      FixBot'a Sor
      Yorum Ekle
    1. UTStarcom XV6700 Camera Replacement, Camera: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
      FixBot'a Sor
      Yorum Ekle
    2. UTStarcom XV6700 Camera Replacement: adım 5, 2 resimden 1. UTStarcom XV6700 Camera Replacement: adım 5, 2 resimden 2.
      • Use firm pressure to carefully pry off the cover with your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. UTStarcom XV6700 Camera Replacement: adım 6, 1 resimden 1.
      • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
      FixBot'a Sor
      Yorum Ekle
    4. UTStarcom XV6700 Camera Replacement: adım 7, 1 resimden 1.
      • Gently pry off the camera flash circuit board with the spudger.
      FixBot'a Sor
      Yorum Ekle
    5. UTStarcom XV6700 Camera Replacement: adım 8, 1 resimden 1.
      • Gently pry off the camera with the spudger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 522
