Giriş
This guide walks you through the steps to replace the external speaker on your phone. You can follow these same steps to check your speaker connection as well.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
