Ana içeriğe geç
UTStarcom XV6700 Screen Replacement
Neye ihtiyacın var
    1. UTStarcom XV6700 Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Press the on/off button on the top to power the phone off.
      FixBot'a Sor
      Yorum Ekle
    2. UTStarcom XV6700 Screen Replacement: adım 2, 1 resimden 1.
      • Remove the battery cover by pressing and sliding the cover down and off of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. UTStarcom XV6700 Screen Replacement: adım 3, 3 resimden 1. UTStarcom XV6700 Screen Replacement: adım 3, 3 resimden 2. UTStarcom XV6700 Screen Replacement: adım 3, 3 resimden 3.
      • Pull the battery removal tab and lift the battery out of the phone.
      • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
      FixBot'a Sor
      Yorum Ekle
    1. UTStarcom XV6700 Screen Replacement, Camera: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
      FixBot'a Sor
      Yorum Ekle
    2. UTStarcom XV6700 Screen Replacement: adım 5, 2 resimden 1. UTStarcom XV6700 Screen Replacement: adım 5, 2 resimden 2.
      • Use firm pressure to carefully pry off the cover with your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. UTStarcom XV6700 Screen Replacement: adım 6, 1 resimden 1.
      • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
      FixBot'a Sor
      Yorum Ekle
    4. UTStarcom XV6700 Screen Replacement: adım 7, 1 resimden 1.
      • Gently pry off the camera flash circuit board with the spudger.
      FixBot'a Sor
      Yorum Ekle
    5. UTStarcom XV6700 Screen Replacement: adım 8, 1 resimden 1.
      • Gently pry off the camera with the spudger.
      FixBot'a Sor
      Yorum Ekle
    1. UTStarcom XV6700 Screen Replacement, Motherboard: adım 9, 1 resimden 1.
      • Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
      FixBot'a Sor
      Yorum Ekle
    2. UTStarcom XV6700 Screen Replacement: adım 10, 1 resimden 1.
      • Remove the 4.0-mm #00 Phillips screw that holds the antenna in place. The antenna does not need to be removed.
      FixBot'a Sor
      Yorum Ekle
    3. UTStarcom XV6700 Screen Replacement: adım 11, 3 resimden 1. UTStarcom XV6700 Screen Replacement: adım 11, 3 resimden 2. UTStarcom XV6700 Screen Replacement: adım 11, 3 resimden 3.
      • Use the spudger or plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
      • Carefully pry the black portion of the case away from the silver portion.
      • Do not try to remove the case completely. The speaker wire is still connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. UTStarcom XV6700 Screen Replacement: adım 12, 1 resimden 1.
      • Using tweezers, pull with gentle pressure in the direction of the wire to unplug from the motherboard connector.
      FixBot'a Sor
      Yorum Ekle
    5. UTStarcom XV6700 Screen Replacement: adım 13, 1 resimden 1.
      • Remove the 4.0-mm #00 Phillips screw holding the motherboard in place. The screw is in the middle of the motherboard, near the outside edge.
      FixBot'a Sor
      Yorum Ekle
    6. UTStarcom XV6700 Screen Replacement: adım 14, 2 resimden 1. UTStarcom XV6700 Screen Replacement: adım 14, 2 resimden 2.
      • With your fingers, disconnect the keyboard cable from the motherboard. The cable is orange with the letters T/B printed on the connector.
      FixBot'a Sor
      Yorum Ekle
    7. UTStarcom XV6700 Screen Replacement: adım 15, 2 resimden 1. UTStarcom XV6700 Screen Replacement: adım 15, 2 resimden 2.
      • Carefully lift up on the motherboard with the spudger until you can see the display cable connected to the underside of the motherboard. The display cable connector will be taped over.
      FixBot'a Sor
      Yorum Ekle
    8. UTStarcom XV6700 Screen Replacement: adım 16, 1 resimden 1.
      • Use the spudger to peel away the tape from the connector.
      FixBot'a Sor
      Yorum Ekle
    9. UTStarcom XV6700 Screen Replacement: adım 17, 1 resimden 1.
      • Using the spudger, pry away the display cable connector from the motherboard. The motherboard is now completely disconnected.
      FixBot'a Sor
      Yorum Ekle
    1. UTStarcom XV6700 Screen Replacement, Screen: adım 18, 1 resimden 1.
      • Remove the four 4.0-mm #00 Phillips screws that secure the slide-out keyboard to the screen enclosure.
      FixBot'a Sor
      Yorum Ekle
    2. UTStarcom XV6700 Screen Replacement: adım 19, 2 resimden 1. UTStarcom XV6700 Screen Replacement: adım 19, 2 resimden 2.
      • Carefully pull the display cable through the opening in the keyboard panel. The keyboard panel can then be set aside.
      FixBot'a Sor
      Yorum Ekle
    3. UTStarcom XV6700 Screen Replacement: adım 20, 1 resimden 1.
      • Remove four 5.0-mm Torx T6 screws from the screen enclosure.
      FixBot'a Sor
      Yorum Ekle
    4. UTStarcom XV6700 Screen Replacement: adım 21, 3 resimden 1. UTStarcom XV6700 Screen Replacement: adım 21, 3 resimden 2. UTStarcom XV6700 Screen Replacement: adım 21, 3 resimden 3.
      • Pry the silver cover off the screen enclosure. The display cable should be pulled through the opening in the silver cover.
      FixBot'a Sor
      Yorum Ekle
    5. UTStarcom XV6700 Screen Replacement: adım 22, 2 resimden 1. UTStarcom XV6700 Screen Replacement: adım 22, 2 resimden 2.
      • Use the spudger to remove the tape from the connector between the screen and the front button circuit board.
      • Pry up on the brown connector to remove.
      FixBot'a Sor
      Yorum Ekle
    6. UTStarcom XV6700 Screen Replacement: adım 23, 1 resimden 1.
      • Remove one 4.0-mm #00 Phillips screws from the silver bracket holding the screen assembly in place.
      FixBot'a Sor
      Yorum Ekle
    7. UTStarcom XV6700 Screen Replacement: adım 24, 3 resimden 1. UTStarcom XV6700 Screen Replacement: adım 24, 3 resimden 2. UTStarcom XV6700 Screen Replacement: adım 24, 3 resimden 3.
      • Remove the screen by using the spudger to gently but firmly pry the screen away from the outer case.
      • Use your hand to lift the screen completely away from the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 723
