Giriş
A damaged camera can drastically limit the functionality of your drone; however, by following these simple camera-replacement steps, you will have your drone taking video and pictures again in no time. You will need a Phillips head screwdriver size PH00 to complete this task.
Neye ihtiyacın var
Place the drone on its back, with the runners facing upward.
Using the Phillips #00 screwdriver, unscrew the single 2mm screw located on the drone body which connects the headlamp and wiring to the center of the drone frame.
