Giriş
If your Udreamer turntable isn’t spinning properly, the belt might need to be replaced. The belt helps the platter spin so your records play correctly. If it's worn, you might notice slow or uneven spinning, or it might not spin at all.
Check the size of the current belt to ensure the correct replacement size. This video demonstrates how to measure if you are unsure of the size.
Before you begin the repair, unplug the turntable. Also, avoid touching the motor or any electronic parts to prevent damage to your unit.
Neye ihtiyacın var
