Ana içeriğe geç
Udreamer Turntable Belt Replacement
Neye ihtiyacın var
  1. Udreamer Turntable Belt Replacement, Belt: adım 1, 3 resimden 1. Udreamer Turntable Belt Replacement, Belt: adım 1, 3 resimden 2. Udreamer Turntable Belt Replacement, Belt: adım 1, 3 resimden 3.
    • Gently pull off the retaining clip at the center of the turntable platter.
    • Put it in a safe spot to avoid losing it as you will need it for reassembly.
  2. Udreamer Turntable Belt Replacement: adım 2, 1 resimden 1.
    • Lift the platter straight up and off the spindle to reveal the belt and motor assembly underneath.
  3. Udreamer Turntable Belt Replacement: adım 3, 1 resimden 1.
    • Carefully stretch the old belt off the motor pulley and platter grooves.
    • Inspect the pulley and platter for debris or damage.
  4. Udreamer Turntable Belt Replacement: adım 4, 2 resimden 1. Udreamer Turntable Belt Replacement: adım 4, 2 resimden 2.
    • Position the new belt around the motor pulley and the inner rim of the platter.
    • Ensure the belt lies flat without twists.
  5. Udreamer Turntable Belt Replacement: adım 5, 3 resimden 1. Udreamer Turntable Belt Replacement: adım 5, 3 resimden 2. Udreamer Turntable Belt Replacement: adım 5, 3 resimden 3.
    • Place the platter back onto the spindle, aligning it with the motor assembly.
    • Hold the belt in place as you lower the platter.
  6. Udreamer Turntable Belt Replacement: adım 6, 3 resimden 1. Udreamer Turntable Belt Replacement: adım 6, 3 resimden 2. Udreamer Turntable Belt Replacement: adım 6, 3 resimden 3.
    • Press the retaining clip back onto the spindle to secure the platter.
    • Ensure the clip is tightly fastened to prevent the platter from wobbling during use.
Sonuç
Gustavo Deveze
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 77
