Ana içeriğe geç
Ulco Integrus PSV Battery Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
    • Before disassembly, make sure the front wheel breaks are on.
    • Make sure ALL gas supplies are disconnected and the system has been purged, and make sure all electrical supplies have been disconnected.
  1. Ulco Integrus PSV Battery Replacement: adım 4, 1 resimden 1.
    • With one hand on the ventilator removal handle and one holding the lower half of the ventilator, pull up firmly on the handle so that the mounting slides up the slots in the frame.
  2. Ulco Integrus PSV Battery Replacement: adım 5, 1 resimden 1.
    • Pull the ventilator housing towards you so that the mounting tabs come out of the frame slots rest the ventilator housing on the plastic skirt at the rear of the workstation as shown in the photo.
  3. Ulco Integrus PSV Battery Replacement, Removing the Rear Access Panels in the Ulco Integrus PSV: adım 6, 1 resimden 1.
    • Remove the rear plastic cover by turning the single hex key retaining clip to free the cover.
  4. Ulco Integrus PSV Battery Replacement: adım 7, 1 resimden 1.
    • Remove the four screws mounted to the cover plate using a 4mm Allen key.
  5. Ulco Integrus PSV Battery Replacement, Battery: adım 8, 1 resimden 1.
    • Remove the main cover plate from the ventilator enclosure by removing all screws.
    • Disconnect the battery.
  6. Ulco Integrus PSV Battery Replacement: adım 10, 1 resimden 1.
    • Remove the four pan head screws (SM0308P) holding down the battery plate (EV9109) and battery (EV9108) and remove the battery plate and battery.
  7. Ulco Integrus PSV Battery Replacement: adım 11, 1 resimden 1.
    • Install the new battery in the same location and screw down the battery plate onto the battery plate spacers so that the battery is firmly held in place.
    • Reconnect the battery.
Sonuç
Preston Myers
493 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G13, Paton Spring 2020 Cal Poly, Team S7-G13, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G13
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 51
