Ana içeriğe geç
Unbranded UB-15MS10 Battery Replacement
Neye ihtiyacın var
    1. Unbranded UB-15MS10 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Use an opening tool to pry off the lid of the memory card compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Unbranded UB-15MS10 Battery Replacement: adım 2, 1 resimden 1.
      • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Unbranded UB-15MS10 Battery Replacement: adım 3, 2 resimden 1. Unbranded UB-15MS10 Battery Replacement: adım 3, 2 resimden 2.
      • Insert opening tools to partially pry open the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Unbranded UB-15MS10 Battery Replacement: adım 4, 1 resimden 1.
      • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
      FixBot'a Sor
      Yorum Ekle
    5. Unbranded UB-15MS10 Battery Replacement: adım 5, 1 resimden 1.
      • Remove the tape that is holding the battery in place.
      FixBot'a Sor
      Yorum Ekle
    6. Unbranded UB-15MS10 Battery Replacement: adım 6, 1 resimden 1.
      • Cut the wires connecting the battery to the device using a pair of wire cutters.
      FixBot'a Sor
      Yorum Ekle
    7. Unbranded UB-15MS10 Battery Replacement: adım 7, 1 resimden 1.
      • Carefully remove the battery, making sure that all wires are disconnected.
      FixBot'a Sor
      Yorum Ekle
    8. Unbranded UB-15MS10 Battery Replacement: adım 8, 1 resimden 1.
      • Splice the new battery with the red, white, and black wires connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow directions 1-7 in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Evan Peterson
338 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 UMass Dartmouth, Team S5-G5, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G5
3 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 2,922
