Ana içeriğe geç
Unbranded UB-15MS10 Battery Replacement
Neye ihtiyacın var
  1. Unbranded UB-15MS10 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
  3. Unbranded UB-15MS10 Battery Replacement: adım 3, 2 resimden 1. Unbranded UB-15MS10 Battery Replacement: adım 3, 2 resimden 2.
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Battery Replacement: adım 4, 1 resimden 1.
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Battery Replacement: adım 6, 1 resimden 1.
    • Cut the wires connecting the battery to the device using a pair of wire cutters.
  7. Unbranded UB-15MS10 Battery Replacement: adım 7, 1 resimden 1.
    • Carefully remove the battery, making sure that all wires are disconnected.
  8. Unbranded UB-15MS10 Battery Replacement: adım 8, 1 resimden 1.
    • Splice the new battery with the red, white, and black wires connected to the motherboard.
Sonuç
To reassemble your device, follow directions 1-7 in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Evan Peterson
320 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 UMass Dartmouth, Team S5-G5, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G5
3 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,619
