Ana içeriğe geç
Uniden D1483-3BK Handset Keypad Replacement
Neye ihtiyacın var
  1. Uniden D1483-3BK Handset Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Handset Keypad Replacement: adım 2, 2 resimden 1. Uniden D1483-3BK Handset Keypad Replacement: adım 2, 2 resimden 2.
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Handset Keypad Replacement: adım 3, 1 resimden 1.
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: adım 4, 2 resimden 1. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: adım 4, 2 resimden 2.
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Handset Keypad Replacement: adım 5, 3 resimden 1. Uniden D1483-3BK Handset Keypad Replacement: adım 5, 3 resimden 2. Uniden D1483-3BK Handset Keypad Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Handset Keypad Replacement: adım 6, 2 resimden 1. Uniden D1483-3BK Handset Keypad Replacement: adım 6, 2 resimden 2.
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Handset Keypad Replacement: adım 7, 2 resimden 1. Uniden D1483-3BK Handset Keypad Replacement: adım 7, 2 resimden 2.
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Handset Keypad Replacement, Handset Keypad: adım 8, 1 resimden 1.
    • Remove the rubber keypad from the front half of the handset case.
    • The keypad comes in two separate pieces.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Arbitrary Name
1.083 İtibar
4 adet Kılavuz yazıldı
Ekip
Penn State, Team 1-8, Kaschak Winter 2015 Penn State, Team 1-8, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S1G8
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 205
