Ana içeriğe geç
Uniden Dect 6.0 Display Replacement
Neye ihtiyacın var
  1. Uniden Dect 6.0 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: adım 2, 1 resimden 1.
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: adım 3, 1 resimden 1.
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: adım 4, 2 resimden 1. Uniden Dect 6.0 Display Replacement, Keyboard: adım 4, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: adım 5, 1 resimden 1.
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: adım 6, 1 resimden 1.
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: adım 7, 1 resimden 1.
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: adım 8, 1 resimden 1.
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: adım 9, 1 resimden 1.
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Megan Lawrence
534 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 42
Her zaman: 6,374
