Ana içeriğe geç
Uniden EXP 371 Antenna Replacement
Neye ihtiyacın var
  1. Uniden EXP 371 Antenna Replacement, Uniden EXP 371 Teardown: adım 1, 1 resimden 1.
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Antenna Replacement: adım 2, 2 resimden 1. Uniden EXP 371 Antenna Replacement: adım 2, 2 resimden 2.
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Antenna Replacement: adım 3, 2 resimden 1. Uniden EXP 371 Antenna Replacement: adım 3, 2 resimden 2.
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Antenna Replacement: adım 4, 3 resimden 1. Uniden EXP 371 Antenna Replacement: adım 4, 3 resimden 2. Uniden EXP 371 Antenna Replacement: adım 4, 3 resimden 3.
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Antenna Replacement, Antenna: adım 5, 2 resimden 1. Uniden EXP 371 Antenna Replacement, Antenna: adım 5, 2 resimden 2.
    • After following the teardown guide. Take the bottom case and locate the antenna at the top of the phone.
    • Lift the bottom of the the antenna with the aid of a tool (these tweezers work well) and push the antenna inside the phone to remove it.
    • To reassemble the phone, follow the steps in the reverse order.
Sonuç
Eric Rodrigues
343 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,256
