Ana içeriğe geç
Uniden EXP 371 Keypad Replacement
Neye ihtiyacın var
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: adım 1, 1 resimden 1.
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: adım 2, 3 resimden 1. Uniden EXP 371 Keypad Replacement: adım 2, 3 resimden 2. Uniden EXP 371 Keypad Replacement: adım 2, 3 resimden 3.
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: adım 3, 2 resimden 1. Uniden EXP 371 Keypad Replacement: adım 3, 2 resimden 2.
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: adım 4, 1 resimden 1.
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: adım 5, 2 resimden 1. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: adım 5, 2 resimden 2.
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: adım 6, 1 resimden 1.
Sonuç
Lucas Mohsen
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 148
