Ana içeriğe geç
Uniden Guardian G955 Battery Replacement
  1. Uniden Guardian G955 Battery  Replacement, Battery: adım 1, 1 resimden 1.
    • First, remove four 6.1 mm screws from your monitor using a J1 Phillips head screwdriver.
  2. Uniden Guardian G955 Battery  Replacement: adım 2, 1 resimden 1.
    • Carefully, use a metal spudger to open the case starting from any corner.
    • Slowly slide the spudger along the inside edge of the case.
  3. Uniden Guardian G955 Battery  Replacement: adım 3, 2 resimden 1. Uniden Guardian G955 Battery  Replacement: adım 3, 2 resimden 2.
    • Remove the two 6.1 mm screws from the black fastener using a screwdriver.
    • Remove the black fastener.
  4. Uniden Guardian G955 Battery  Replacement: adım 4, 2 resimden 1. Uniden Guardian G955 Battery  Replacement: adım 4, 2 resimden 2.
    • Disconnect the head of the cable attached to the motherboard by pressing on the outer edge of the cable and sliding it out.
  5. Uniden Guardian G955 Battery  Replacement: adım 5, 2 resimden 1. Uniden Guardian G955 Battery  Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the case by sliding a halberd spudger below it. (note: the spudger shown is metal, to ensure proper safety, utilize a nylon or plastic spudger.)
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sundus Al Shibani
180 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Nance Fall 2016 USF Tampa, Team 1-1, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G1
3 Üyeler
8 adet Kılavuz yazıldı
4 Yorum
The instructions and illustrations are fine, but there is NO information on how to obtain a replacement battery. I have searched without any luck.
Ricaedo Garcia - Yanıt
Hello, I sure hope I can get a answer on this, Ricaedo Garcia was you able to find a replacement battery for yours. I been searching for one and no luck. Thank you
Kathy -
I’m going to try using this battery: YK843553-Battery-for-UNIDEN-UBW2101C-Camera-UBWC21-1250mAh
I think it will work. The connector and voltage are the same.
George Scott - Yanıt
George Scott: Did that battery work satisfactorily?
PhBob - - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 5,619
