Ana içeriğe geç
Uniden TCX905 Earpiece Speaker Replacement
Neye ihtiyacın var
  1. Uniden TCX905 Earpiece Speaker Replacement, Battery Cover: adım 1, 2 resimden 1. Uniden TCX905 Earpiece Speaker Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Earpiece Speaker Replacement, Battery Pack: adım 2, 2 resimden 1. Uniden TCX905 Earpiece Speaker Replacement, Battery Pack: adım 2, 2 resimden 2.
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Earpiece Speaker Replacement, Back Shell: adım 3, 2 resimden 1. Uniden TCX905 Earpiece Speaker Replacement, Back Shell: adım 3, 2 resimden 2.
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Earpiece Speaker Replacement: adım 4, 3 resimden 1. Uniden TCX905 Earpiece Speaker Replacement: adım 4, 3 resimden 2. Uniden TCX905 Earpiece Speaker Replacement: adım 4, 3 resimden 3.
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Earpiece Speaker Replacement: adım 5, 3 resimden 1. Uniden TCX905 Earpiece Speaker Replacement: adım 5, 3 resimden 2. Uniden TCX905 Earpiece Speaker Replacement: adım 5, 3 resimden 3.
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Earpiece Speaker Replacement, Circuit Board: adım 6, 2 resimden 1. Uniden TCX905 Earpiece Speaker Replacement, Circuit Board: adım 6, 2 resimden 2.
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Earpiece Speaker Replacement: adım 7, 3 resimden 1. Uniden TCX905 Earpiece Speaker Replacement: adım 7, 3 resimden 2. Uniden TCX905 Earpiece Speaker Replacement: adım 7, 3 resimden 3.
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
  8. Uniden TCX905 Earpiece Speaker Replacement, Earpiece Speaker: adım 8, 2 resimden 1. Uniden TCX905 Earpiece Speaker Replacement, Earpiece Speaker: adım 8, 2 resimden 2.
    • Place circuit board gently on the back shell with the earpiece facing up
  9. Uniden TCX905 Earpiece Speaker Replacement: adım 9, 3 resimden 1. Uniden TCX905 Earpiece Speaker Replacement: adım 9, 3 resimden 2. Uniden TCX905 Earpiece Speaker Replacement: adım 9, 3 resimden 3.
    • Pry speaker gently from setting using tweezers
    • Cut red and black wires near the soldering
Sonuç
Gary Pence
807 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-1, Benson Spring 2014 Clemson, Team 1-1, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G1
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 487
