Ana içeriğe geç
Uniden UTAB71 Camera Replacement
Neye ihtiyacın var
  1. Uniden UTAB71 Camera Replacement, Camera: adım 1, 2 resimden 1. Uniden UTAB71 Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: adım 2, 2 resimden 1. Uniden UTAB71 Camera Replacement: adım 2, 2 resimden 2.
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: adım 3, 1 resimden 1.
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: adım 4, 3 resimden 1. Uniden UTAB71 Camera Replacement: adım 4, 3 resimden 2. Uniden UTAB71 Camera Replacement: adım 4, 3 resimden 3.
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Sonuç
Ryan Jewell
422 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Martin Fall 2016 UMass Dartmouth, Team 5-4, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 166
