Ana içeriğe geç
Uniden UTAB71 Screen Replacement
Neye ihtiyacın var
  1. Uniden UTAB71 Screen Replacement, Screen: adım 1, 2 resimden 1. Uniden UTAB71 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Use a pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Screen Replacement: adım 2, 2 resimden 1. Uniden UTAB71 Screen Replacement: adım 2, 2 resimden 2.
    • Lift off the black clip connecting the first power ribbon to the motherboard
    • Undo the clips off the second power ribbon connecting the screen to the motherboard.
  3. Uniden UTAB71 Screen Replacement: adım 3, 3 resimden 1. Uniden UTAB71 Screen Replacement: adım 3, 3 resimden 2. Uniden UTAB71 Screen Replacement: adım 3, 3 resimden 3.
    • Slowly remove the screen component off the tablet by clipping the screen from the tablet outine
    • Do not apply too much pressure on the tablet casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Jewell
422 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Martin Fall 2016 UMass Dartmouth, Team 5-4, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 361
