Ana içeriğe geç
Unihut Titan Pocket Keyboard Disassembly Guide
Neye ihtiyacın var
  1. Unihut Titan Pocket Keyboard Disassembly Guide, Side plates disassembly: adım 1, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Side plates disassembly: adım 1, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Side plates disassembly: adım 1, 3 resimden 3.
    • Use a Torx T5 screwdriver to remove the 3 screws.
    • Remove the Sim tray.
  2. Unihut Titan Pocket Keyboard Disassembly Guide, Back plate screws: adım 2, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the 4 screws.
  3. Unihut Titan Pocket Keyboard Disassembly Guide, Back plate disassembly: adım 3, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Back plate disassembly: adım 3, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Back plate disassembly: adım 3, 3 resimden 3.
    • Insert the opening pick into the gap between the body and the back plate. Then open the gap so that the latch comes out.
    • There are three latches on the left and right, one on the top and two on the bottom.
  4. Unihut Titan Pocket Keyboard Disassembly Guide, Bottom part disassembly: adım 4, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Bottom part disassembly: adım 4, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Bottom part disassembly: adım 4, 3 resimden 3.
    • Remove the 3 screws using a Phillips #000 screwdriver.
    • Use the opening tool to open the gap.
  5. Unihut Titan Pocket Keyboard Disassembly Guide, Battery disassembly: adım 5, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Battery disassembly: adım 5, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Battery disassembly: adım 5, 3 resimden 3.
    • Remove the battery connector.
    • Do not remove including a black sponge. Only disconnect the silver connector.
    • Then, lift the battery.
  6. Unihut Titan Pocket Keyboard Disassembly Guide, Upper part disassembly: adım 6, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Upper part disassembly: adım 6, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Upper part disassembly: adım 6, 3 resimden 3.
    • Remove the 2 screws using a Phillips #000 screwdriver.
    • Lift the top part with the pointed part of the Spudger.
    • You don't have to remove the metal sticker by just lifting the top part.
    • If the camera or earphone jack connector is disconnected during the lifting process, reconnect it.
  7. Unihut Titan Pocket Keyboard Disassembly Guide, Motherboard disassembly: adım 7, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Motherboard disassembly: adım 7, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Motherboard disassembly: adım 7, 3 resimden 3.
    • Disconnect the 6 connectors.
    • Remove the 5 screws using a Phillips #000 screwdriver.
    • Use the Spudger to lift the top of the motherboard.
  8. Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: adım 8, 3 resimden 1. Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: adım 8, 3 resimden 2. Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: adım 8, 3 resimden 3.
    • Insert a thin thing such as a Sim pin through the hole where the screw was removed and push the keyboard out.
  9. Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: adım 9, 1 resimden 1.
    • Remove the 17 plastic rivets to separate the board and keyboard.
    • Since plastic rivets cannot be reused after they are initially removed, they must be reassembled using tools such as glue.
Sonuç
To reassemble the device, follow the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
ko en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
glwps
301 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 62
Son 30 gün: 238
Her zaman: 4,383
