Ana içeriğe geç
Unnecto Drone M Headphone Jack Replacement
Neye ihtiyacın var
  1. Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: adım 1, 2 resimden 1. Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: adım 1, 2 resimden 2.
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Unnecto Drone M Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Unnecto Drone M Headphone Jack Replacement: adım 3, 1 resimden 1.
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. Unnecto Drone M Headphone Jack Replacement: adım 4, 1 resimden 1.
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  5. Unnecto Drone M Headphone Jack Replacement: adım 5, 2 resimden 1. Unnecto Drone M Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  6. Unnecto Drone M Headphone Jack Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  7. Unnecto Drone M Headphone Jack Replacement: adım 7, 1 resimden 1.
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  8. Unnecto Drone M Headphone Jack Replacement: adım 8, 2 resimden 1. Unnecto Drone M Headphone Jack Replacement: adım 8, 2 resimden 2.
    • Set aside the circuit board from the screen protector.
  9. Unnecto Drone M Headphone Jack Replacement, Headphone Jack: adım 9, 3 resimden 1. Unnecto Drone M Headphone Jack Replacement, Headphone Jack: adım 9, 3 resimden 2. Unnecto Drone M Headphone Jack Replacement, Headphone Jack: adım 9, 3 resimden 3.
    • Desolder the headphone jack using a soldering iron on each of the 6 points holding it down.
    • Be careful to not damage the circuit board.
  10. Unnecto Drone M Headphone Jack Replacement: adım 10, 2 resimden 1. Unnecto Drone M Headphone Jack Replacement: adım 10, 2 resimden 2.
    • Solder on a new headphone jack.
  11. Unnecto Drone M Headphone Jack Replacement: adım 11, 1 resimden 1.
    • Make sure the new jack is aligned properly and securely soldered to the circuit board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 196
