Ana içeriğe geç
Unsticking SteelSeries Nimbus Triggers
Neye ihtiyacın var
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: adım 1, 1 resimden 1.
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: adım 2, 2 resimden 1. Unsticking SteelSeries Nimbus Triggers: adım 2, 2 resimden 2.
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: adım 3, 3 resimden 1. Unsticking SteelSeries Nimbus Triggers: adım 3, 3 resimden 2. Unsticking SteelSeries Nimbus Triggers: adım 3, 3 resimden 3.
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: adım 4, 2 resimden 1. Unsticking SteelSeries Nimbus Triggers: adım 4, 2 resimden 2.
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: adım 5, 3 resimden 1. Unsticking SteelSeries Nimbus Triggers: adım 5, 3 resimden 2. Unsticking SteelSeries Nimbus Triggers: adım 5, 3 resimden 3.
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: adım 6, 3 resimden 1. Unsticking SteelSeries Nimbus Triggers: adım 6, 3 resimden 2. Unsticking SteelSeries Nimbus Triggers: adım 6, 3 resimden 3.
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: adım 7, 2 resimden 1. Unsticking SteelSeries Nimbus Triggers: adım 7, 2 resimden 2.
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jonathan
464 İtibar
2 adet Kılavuz yazıldı
4 Yorum
Great, concise fix instructions!
Brian Pippen - Yanıt
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - Yanıt
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - Yanıt
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 12
Son 30 gün: 57
Her zaman: 6,263
