Ana içeriğe geç
Untracked Bifold Door Pin Replacement
Neye ihtiyacın var
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: adım 1, 1 resimden 1.
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: adım 2, 1 resimden 1.
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: adım 3, 1 resimden 1.
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: adım 4, 2 resimden 1. Untracked Bifold Door Pin Replacement: adım 4, 2 resimden 2.
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: adım 5, 1 resimden 1.
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: adım 6, 1 resimden 1.
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: adım 7, 1 resimden 1.
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: adım 8, 1 resimden 1.
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: adım 9, 1 resimden 1.
    • When completed, the bifold doors should close and be positioned within the tracking.
Sonuç
Catelyn Carpenter
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 58
Her zaman: 1,315
