Giriş
This guide is here to help you upgrade your Late 2008 2.0 GHz Aluminum Unibody MacBook to have a backlit keyboard without buying an entire new topcase. Keyboards can be purchased off Ebay for less than $75.
Neye ihtiyacın var
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
Remove the single Phillips screw securing the subwoofer to the upper case.
Peel back the small piece of black tape covering the right speaker cable.
Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
Lift the subwoofer and right speaker assembly out of the upper case.
I left it in place. It was not necessary to remove it for replacement of the keyboard.
Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
Pull the IR sensor ribbon cable straight away from the logic board.
Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
Pull the keyboard ribbon cable straight out of its socket.
When you are on the way back, this is where you can connect the keyboard lighting. You put the flat cable from the new keyboard into the connector directly to the right of the one for the keyboard ribbon cable. It shows itself!
Remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
Lift the bottom case clip out of the upper case.
Remove the following five screws securing the logic board to the upper case:
Four 3 mm Phillips screws.
One 3.5 mm Phillips screw.
Remove the two 7 mm Phillips screws securing the DC-in board to the upper case.
Lift the logic board from its left edge and pull it out of the upper case.
Note to Step 41: the 3.5 mm Phillips screw and the 3 mm Phillips screw directly opposite were swapped in my MacBook. I believe the screws as indicated in the iFixIt guide are currently incorrect as it seems that the location in my MacBook would be correct as all 3 mm screws engage directly into the top case while the one 3.5 mm screw engages into the black bracket.
De-route the battery connector cable through the gap in the upper case and remove it from the computer.
During your checkout of your hard work, make sure in System Preferences that the (use all F1, F2 etc. keys as standard function keys) box is unchecked.
It was not necessary to remove this item for me. I could remove the keyboard with it in place
Now that you have removed the display (only required if a new top case is used to replace the keyboard), logic board, optical drive, and various other components from the upper case (or top case), you should have something that looks like this.
We are ready to begin!
Pictures missing fix it please
The photo is missing for lots of these steps
More picture for whats?
Now you will see a large clear plastic wafer stuck to the back of the keyboard.
You can remove this easily buy peeling it up slowly.
Listings on ebay offer only this part as a backlight component. Is that enough just to replace this wafer to have a backlight?
Now you have all probably noticed the horde of tiny black screws that cover the back of your keyboard. Yes, unfortunately we have to to take 'em out!
I had only 59 screws, still it seems OK..
I count 68 screws
Yikes, I only counted 49. If you include the power button as well, 51. But, I could have easily miss counted, and the keyboard isn't going anywhere.
Now that you have removed all of the screws, you can gently press on the face side of the keyboard and it will come right out. (If you have removed all the screws.)
Here is an image of the top case without its keyboard. I hope you're not winded yet. We're only half way there!
33 farklı kişi bu kılavuzu tamamladı.
16 Yorum
The photos which show how to install the backlit aren't showing. Is there maybe another thread which shows them because I can't really figure it out .
The photos aren't failing to show up, there just aren't any photos - no one ever uploaded any, even though the text of the guide talks about the pictures. As you're doing the upgrade yourself though, snap some pictures, edit the steps here, and upload your pictures!
just a question. Where exactly do I put the backlight? Because I have a black film, then a thick plastic sheet, then the metal. then the silicon layer with the components inside, and then the front black sheet, and above that you mount the keys. In between which layer do I put the backlight?
Remove black film and put your backlit
I realize that this guide is getting a bit old, but I bought just the backlight part off Ebay. It's essentially a black film with couple of leds, a clear plastic sheet and a black matte layer. It goes on top (if you look at the MB from the bottom, as in this guide) the metal layer. So it replaces the parts you remove in steps 32 and 33, after which you can start reassembling.
I did this last night and steps 29 and 30 aren't required if this is just a guide to replace the keyboard with a backlit keyboard, and not a new top case. Also, the steps to remove two small brackets on either side of the case near the display to allow access to the mic and to remove cable held down by them, are missing. They should be part of step 18 and 27.
Also, step 31 should read:
Now that you have removed the display(not required if just the keyboard is replaced), logic board, optical drive, and various other components from the upper case (or top case) You should have something that looks like this!
PLEASE NOTE- You MUST reset the SMC after upgrading to the backlit keyboard in order for the MacBook to recognize the new keyboard. See how to do it here:
Hello everyone. I apologise for my bad english in advance.
I own a MacBook late 2008 with the NON backlit keyboard.
I just got a new topcase with backlit.
I just wanted to ask, is it somehow possible to have backlight works when my logic board doesnt has the necessary socket to accept the keyboard backlight ribbon cable?
And if yes, how?
Thanks in advance.
Greetings from Greece.
Nick
probably not, I'm sorry
Zaim -
I did, thaks for tutorials. It's work!
you are welcome
Zaim -
wow, so many steps only for get a backlit..why apple's not just make it as easy as thinkpad keyboard.....? ck..ck..ck
Hi to everyone, I have some problem with replacement. After installation and reseting SMC and NVRAM, my backlight still doesn't work. After reseting NVRAM it flash 1 time and it's all. on pressing F5 or F6 it shows me backlight error popup.
After installing the backlight I cleared the Nvram but that did not enable the backlight; i was still getting the ‘non functioning’ symbol when clicking F5 or F6.
I then went to System Preferences -> Keyboard and unticked ‘Adjust keyboard brightness in low light’. Then it worked.
Thanks for the tutorial, it worked perfectly for me too!
is it still possible to have a backlight keyboard, even if theres no socket installed?
nightwalkerosfp - Yanıt
I would like to know as well. Can a socket be soldered to the board in this spot?
metalman141 - Yanıt
I dont think so coz if apple havent soldered necessary driver chip and circuit for backlight, there is no need to solder that socket. That chip has to be on other side of the board
Oleg R -
Yes I believe it can as that is just power for the backlight I believe.... but I have never done this mod to a macbook without the socket.
Nathanael - Yanıt
The socket for the backlight was snap off when I was removing the ribbon cable. Does anyone know where can I get a replacement for the socket?
Ryan Lim - Yanıt
If you have the skill to solder a new connector on, the best option would probably be to look for a donor motherboard.
Bagel -
