Ana içeriğe geç
Using a Floor Jack
Neye ihtiyacın var
  1. Using a Floor Jack, Using a Floor Jack: adım 1, 2 resimden 1. Using a Floor Jack, Using a Floor Jack: adım 1, 2 resimden 2.
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
    FixBot'a Sor
    Yorum Ekle
  2. Using a Floor Jack, Using floor jack to lift car.: adım 2, 1 resimden 1.
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
    FixBot'a Sor
    Yorum Ekle
  3. Using a Floor Jack: adım 3, 1 resimden 1.
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
    FixBot'a Sor
    Yorum Ekle
  4. Using a Floor Jack: adım 4, 1 resimden 1.
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Shaun MacDonald
2.654 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G27
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 56
Son 30 gün: 230
Her zaman: 44,108
