Ana içeriğe geç
VENSTAR Taco Disassembly
Neye ihtiyacın var
  1. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: adım 1, 3 resimden 1. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: adım 1, 3 resimden 2. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: adım 1, 3 resimden 3.
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Disassembly: adım 2, 2 resimden 1. VENSTAR Taco Disassembly: adım 2, 2 resimden 2.
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Disassembly: adım 3, 2 resimden 1. VENSTAR Taco Disassembly: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    Satın Al
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Disassembly: adım 4, 2 resimden 1. VENSTAR Taco Disassembly: adım 4, 2 resimden 2.
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Disassembly: adım 5, 2 resimden 1. VENSTAR Taco Disassembly: adım 5, 2 resimden 2.
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 408
