Giriş
This guide describes the necessary steps to replace the logic board. This guide is used to replace smaller components within the logic board, such as the micro USB and auxiliary ports. When following this guide, you will need a plastic opening tool and a Phillips PH0 screwdriver.
Neye ihtiyacın var
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Bu adımda kullanılan alet:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
