Ana içeriğe geç
VENSTAR Taco Microphone Replacement Replacement
Neye ihtiyacın var
  1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: adım 1, 3 resimden 1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: adım 1, 3 resimden 2. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: adım 1, 3 resimden 3.
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
    FixBot'a Sor
    Yorum Ekle
  2. VENSTAR Taco Microphone Replacement Replacement: adım 2, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 2, 2 resimden 2.
    • Repeat the previous step on the opposite side to remove the other outer casing.
    FixBot'a Sor
    Yorum Ekle
  3. VENSTAR Taco Microphone Replacement Replacement: adım 3, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
    FixBot'a Sor
    Yorum Ekle
  4. VENSTAR Taco Microphone Replacement Replacement: adım 4, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 4, 2 resimden 2.
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
    FixBot'a Sor
    Yorum Ekle
  5. VENSTAR Taco Microphone Replacement Replacement: adım 5, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 5, 2 resimden 2.
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
    FixBot'a Sor
    Yorum Ekle
  6. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the rubber covering from the buttons.
    FixBot'a Sor
    Yorum Ekle
  7. VENSTAR Taco Microphone Replacement Replacement: adım 7, 3 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 7, 3 resimden 2. VENSTAR Taco Microphone Replacement Replacement: adım 7, 3 resimden 3.
    • Remove the black fabric covering the logic board.
    FixBot'a Sor
    Yorum Ekle
  8. VENSTAR Taco Microphone Replacement Replacement: adım 8, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 8, 2 resimden 2.
    • Move the battery out of the way of the connector.
    FixBot'a Sor
    Yorum Ekle
  9. VENSTAR Taco Microphone Replacement Replacement: adım 9, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 9, 2 resimden 2.
    • Undo the connector of the flat white ribbon between the switches and the logic board.
    FixBot'a Sor
    Yorum Ekle
  10. VENSTAR Taco Microphone Replacement Replacement: adım 10, 1 resimden 1.
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. VENSTAR Taco Microphone Replacement Replacement: adım 11, 3 resimden 1. VENSTAR Taco Microphone Replacement Replacement: adım 11, 3 resimden 2. VENSTAR Taco Microphone Replacement Replacement: adım 11, 3 resimden 3.
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
    FixBot'a Sor
    Yorum Ekle
  12. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: adım 12, 2 resimden 1. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: adım 12, 2 resimden 2.
    • Below the logic board, the small black microphone is resting within the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 41
Her zaman: 459
